1 - 2 of 2 Posts
Hello all,
Let me start by saying I'm new to this group, and wanted to let everyone know how much useful information I've already found on here. this looks like a great community!
I've been wanting to upgrade my 96 LX escort (auto trans) with the basic 3-gauge cluster (fuel, temp, speedo) to a cluster with a tach for some time, and finally found a good one on ebay from the same year. So i dissassembled the car over the weekend, and swapped the cluster out (switching my speedo into the new cluster). I hoped the Tach would get a signal from one of the three wiring harnesses, but it didn't work.
Then I found FEOA, and read through all the postings and saw many people have tried this.. Lots of good advice. I see I need to hook a wire up to the second connector of the EDIS in the engine compartment, but I was left a little confused.. where would the other wire of this connect to? Do I need to run it through the firewall and directly connect it to the tach gauge somewhere, or does it splice into a wire on the wiring harness? Any tips on this would be GREATLY appreciated. :D
Thanks in advance!
best bet is to get a repair book and compare the 2 diagrams together to figure out which wires carry signals, which ones need switching around and if some need to be added. Not too difficult of a task if you do your research
1 - 2 of 2 Posts
