Switchbacks | Ford Escort Owners Association (FEOA)
Switchbacks
Discussion in 'Electrical' started by novanutcase, Mar 23, 2019.
  1. novanutcase
    novanutcase FEOA Member
    2,517
    595
    263
    I bought some swithchback LED lights for the front turn signals along with a loom wired with 6 ohm voltage drops. The amber leds turn on when I hit the turn signal but the white running leds do not light up.
    Any suggestions or troubleshooting?
    John
  2. denisond3
    10,046
    2,777
    No verified suggestions. I found that leds take about 2.5 to 3.5 volts across the leads before they light, and the voltage is slightly different for different colors and different makers. So I would check what the voltage was right at the led, if possible.
  3. novanutcase
    2,517
    595
    263
    From the research I've done it seems that switchbacks work by switching the polarity of the wiring. I have Amber/White switchbacks meaning running lights on will be white and when I turn on the turn signal it should switch from between white and amber until I turn off the turn switch and should return back to just running light white.
    This diagram is what I'm basing my assumptions:
    [​IMG]
    Here's a link to the troubleshooting page I got the above image from. Lots of good info on switchback operation.
    http://www.autolumination.com/switchback_wiring.html
    I'm not sure how the Escort handles power supply to the turn signal. It would seem that they do it the conventional way by running a higher power relay for the turn signal switching and constant power for the running lights. Any suggestions as to how I can make this work with the Escort wiring? I'm thinking to get them to work I'm going to have to wire up some sort of relay system that switches polarity from the OEM bulb holder to get the white running lights to work. Any suggestions?
    John
  4. marclar
    8,928
    527
    seabeck WA
    switch back works by reversing the power +/-. the vehicle is not wired in this way. there is +12 for running lights, and +12 for turn indicators, ground. you would need a controller box to make that work.
  5. novanutcase
    2,517
    595
    263
    How could I modify the factory wiring to switch the polarity to make them work? Relay?
    John
  6. zzyzzx
    15,039
    1,181
    Yes, a relay would do this, but you would still need something to control the relay.
  7. novanutcase
    2,517
    595
    263
    How about a relay that switches polarity?
    In one mode it turns on the turn signal normally and in the other mode, triggered by either the running or headlights it goes into switching polarity?
    The way it is now with or without lights on it will flash normally. That works for daytime driving. I need to polarity switch once the running/headlights get turned on.
    John
  8. zzyzzx
    15,039
    1,181
    A 12V DPDT relay can easily be wired switch polarity when activated. You would need to set power to the coil part when the headlights are on then.
    denisond3 likes this.
  9. marclar
    8,928
    527
    seabeck WA
    i think you would need 2, 5 pin relays.
  10. zzyzzx
    15,039
    1,181
    A single DPDT relay should work. The output to the lights would be the center of the relay outputs.
  11. novanutcase
    2,517
    595
    263
    One for each light or will one control both?
    John
  12. denisond3
    10,046
    2,777
    I think you need one DPDT relay for each side of the car; so on a left turn the left signal can be switched by the relay, while the right side would remain unswitched. viceversa on a right turn.
  13. zzyzzx
    15,039
    1,181
    One for each side.
  14. novanutcase
    2,517
    595
    263
    Thanks! I think I'm going to do all this on the ohm drop loom so I'm not cutting into the stock loom.
    John
  15. marclar
    8,928
    527
    seabeck WA
    your probly right. im doing heads on a 3.5 kia right now. cant spare any extra brain.
  16. novanutcase
    2,517
    595
    263
    12 VDC 10 amp DPDT 135Ω Coil relay switch.
    [​IMG]
    LED Amp drop loom
    [​IMG]
    Will the DPDT relay in the picture work for what I want to do? Can anyone tell me where I need to cut into the loom and what tabs do I solder them to on the relay?
    John
  17. novanutcase
    2,517
    595
    263
    Anyone? Bueller?
    John
  18. zzyzzx
    15,039
    1,181
    The stuff starting at 3:51 is what I was trying to explain:
  19. novanutcase
    2,517
    595
    263
    So having watched the part you posted I understand better how the relay works but I need to know what pin does what to be able to connect them properly. The video uses a 6 pin DPDT relay while mine is an 8 pin.
    John
  20. zzyzzx
    15,039
    1,181
    I would need the info on your relay.
    Having said that, use the contact portion like shown in the video and use the coil part to switch the switch.
