1 - 16 of 16 Posts
You talking about the white one or the purple one?
I love the 17´s on the white scort. They´re tight. How much were they?
Also, the wheel on the purple scort is tight too...
I wouldn´t mind having a new wheel like that. Where did you pick it up? How much was it? It looks like a grant GT wheel. Did you have to buy adapters?
The stock one is too hard to hang onto when your palms get all sweaty, and the grip placement isn´t that great. It´s a little too flexy for my tastes too...
MODERATE THIS!!!
[ This message was edited by: siragan on 13-04-2003 19:25 ]
well dude the purple one is the white one before i painted it and the blue one is the one on page 3 and the steering wheel is 90$ + 27 for The Adapter It Did Not come With The Toggle switch Or The Clutch switch I Installed That Myself
It Is Fun As Hell To Drive With that Steering wheel The Old BIG one Had To Go :-]
Hi Chad,
I looked at your ride and the interior is sweet....what have you done to your old and ugly gray plastic console ? Have you painted it or have you just completely replaced it with a custom one?....
I´m kinda tired of that ugly gray color and I was wondering if it was possible to paint it...or if not...would it be because the paint would come off too easily from the plastic console...I dont know if you get the point..my english kinda S*cks....
Neways..tanx
MD :-]
Discussion Starter · #10 ·
well i took out the whole dash and cleaned scuffed it up then i wiped it down
with paint thinner so the paint does not have fish eyes then i got some white
Interior Paint it is duarable flexable and withstands lots of heat from the sun
well i sprayed the dash about 11 coats i got it real thick so it dont scratch and
then applied 3 coats of clear this is all done with a spray gun not spray can.
for the doors i ripped off all the carpet on the doors and got new red carpet
and used adhesive for that the center consoul is out of a escort with red
interior along with the seats it was a hard process of removing the dash but
its well worth it at the end it is the sweetest interior most people
see in a escort
Chad Bird
[ This message was edited by: Escortrus91 on 16-04-2003 10:35 ]
· Premium Member
[/TD][/TR][TR][TD]
14-04-2003 at 14:46, Escortrus91 wrote:
i put a starter selonoid in my clutch linkage so when i push the button on the steering wheel it pushes the clutch in it is real good for racing
[/TD][/TR][TR][TD]
[/TD][/TR][/TABLE]
How? the starter solonoid is electrical, and a clutch is hydrolic in a second gen and cable driven in a first gen.
You must of left somthing out.
Discussion Starter · #14 ·
Well i put the starter selonoid right next to the Hydraulic piston that pushes the clutch arm that is attached to the throw bearing. The shaft inside the selonoid pushes on the arm that is attached to the throw bearing it workes just like the stock one but a lot faster i maid brackets for the selonoid to bolt up next to the arm right next to the stock piston. And i kept the stock one in there so i can take off in 1st without dumping the clutch with the selonoid.
A Very Confusing Process But It Is Worth It I Can Chirp The Tires In 3rd
And Speed Shift Hella Fast!!
*"TIP"* Bareley Any Matinence Requried With A Hi Performance Selonoid.
Northern Lites Customs
Chad Bird
[ This message was edited by: Escortrus91 on 16-04-2003 23:03 ]
Discussion Starter · #16 ·
well i took my whole tranny out to install it and i got a floor hoist so probley in a driveway like 2 days to install it is a diffulct process to tackle vey hard took me one day with all the tools i needand there are too many tools to list i will try and get some pics for ya guys. ok
oh and 113 dollars for the hi performance selonoid.
Chad Bird
[ This message was edited by: Escortrus91 on 17-04-2003 11:59 ]
1 - 16 of 16 Posts
