1 - 2 of 2 Posts
how much trouble should this be to get back in? when i start it in on one side it has about 4 inches on the other side liking goin back in. could mine be warped?
Put the sway bar in the right control arm, startv thesway bar nut. Leave the mounting brackets for the sway bar off for now. Then take the left control arm off at the frame rail, the 18 mm nut, not at the ball joint. Swing the control arm around to get the sway bar through it. Reinstall the control arm.
1 - 2 of 2 Posts
