I have a 1995 wagon. Just replaced the alternator. While installing the new alt, I noticed that I was leaking coolant. Did not find source. Any ideas?
Yeah, where? There's the overflow by the alt, the hose from the rad cap to expansion tank/overflow, rad cap, water pump, head gasket, freeze plugs, heater core. ^all those are just the passenger side of the engine. I would take a picture of it. Better yet (carefully) look for coolant leaks when the engine is warm... It should be pressurized, and hopefully the leak will show itself.
Get a pressure tester as a free loaner too at AutoZone or Advance Auto. I found my head gasket leak that way. In your case, it probably something else
