I just got my VAF (Apexi) hooked up on my E-gt (1993) , Car runs very good, all the power is there and some more (MUUUHHHAAHHAH), the only problem is, Does anybody know the color or were you hook up the throttle wire off the PCM for the VAF? The reason is because, when we had it hooked up to the Throttle out put, it would not let me rev above 2500RPM's so we unhooked it and it ran like a striped ape. Does anyone have one of theses hooked up on there escort. ahhh it makes the RX-7 VAF scream. I have the green ford books and the chiltons man's and two brain could not figure out only this one wire. I would thank you if you could help. Just neee to know which wiore it is off the PCM so i can get the throttle reading because it reads as it is full throttle.
with the Key in the ON position the throttle works but with the Car running in stays a 100%.
