sub woofer prob | Ford Escort Owners Association (FEOA)
sub woofer prob
Discussion in 'ICE (In Car Entertainment)' started by crazyangel, May 18, 2011.
  1. crazyangel
    crazyangel New Member
    28
    I have a kicker cvr 12 400rms and 800 max daul 4ohm speaker hooked to Sony XM-GTX1302 i have it in a 2qf box. when i turn it up the speaker moves but i dont get alot of bass from it and it sounds like crap.. any help be great thanks
  2. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    is the box ported or sealed?
    are the positive and negative wire hooked up correctly?
    NEUMAN
  3. crazyangel
    28
    I have it hooked up in a 4ohm way pos hooked to 1 coil and neg hooked to other and jump the other 2 2 pos you i didn't hook up to neg i didn't hook up
  4. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    cvr's come in dual 4 or dual 2. if you have it wired like that and its a dual 4 (which most shops sell the general user) you will see 8ohm. this will hurt nothing but it will also not let your amp perform to its peak.
    please answer what box type you have also.
    NEUMAN
  5. crazyangel
    28
    it's in a sealed box .. so should i get the 2ohm dual than? i asked 1 of my friends and they said it wouldnt make 2 much of a diffrence being 2ohm or 4
  6. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    2 cubes sealed is most likely your issue. that is entirely way to much sealed volume for that sub. throw a port in the box a nice 3" tube about 12" long would be perfect. should solve your issue. if it doesn't then you got more issues then i can see from here.
    NEUMAN
  7. crazyangel
    28
    I had it in a little over a 1 cube box and it was worst when i stuck it in this box it sounded better.. i'll have to try a ported box.. thanks
  8. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    i just looked over the specs again. i must have misread the first go. 1 cube sealed to 1.25 would be prime. 1.75 to 2.5 ported is prime also. something is wrong else where. the box should be ported if its up at 2 cubes but really shouldn't be doing the no sound thing.
    NEUMAN
  9. crazyangel
    28
    my box measure is 16" tall 16" wide 17 3/8 long.. i had scrap wood around that i used. might need to cut the box and make it shorter
  10. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    those mesurements are roughly 1.91 cu ft. port displacement will be rougly .05. this brings the box to about 1.86. that is a really fair size. i don't know what would be causing the issue after you port it.
    NEUMAN
  11. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    could the voice coil on the sub be on the way out? i assume your ground is good cause you said it has sound but not alot. is the gain on the amp tuned properly?
  12. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    if the VC was going it would be one of two things. gone or noisy. if the spider or motor was weak it would most likely just bottom out from the weight of the woofer.
    NEUMAN
  13. taylorpro
    taylorpro New Member
    116
    im willing to bet its a phasing issue (issue with polarity). Neuman is right in the sense that the box should be ported at that size, but even if it remains sealed, it should still play well just at a horrible bandwidth.lol. i'd pull the sub and recheck the wiring. make sure you have it wired correctly. if its a D4 sub, you can only wire to 2 or 8 ohm, so make sure thats what you intended. also, check ur gain as mentioned before, and whatever you do, do NOT turn ANY bass boost features on.
  14. crazyangel
    28
    I found out what was wronge with the sub.. the wiring i used i think the aca's are no good.. i ran diffrent set and now it sounds great.. thanks for all your help
