My Escort has done this before a few times. It hasnt done it
in a long time though. Just wait and see how they keep working
for a few. ;-)
for a few. ;-)
I would have to remove my door panel to get to the latch, correct? And the cleaning compund is called "tuner cleaner" and it's used to clean electrical contacts (orogionally intended for mechanical tuners in TV's).siragan said:james-
your motor and shit are fine... the LATCH that latched the door onto the gold colred bar is actually also a switch for the seatbelts. It´s normal for this to get gunked up and so stop opening back up by itself, so the seatbelts will get stuck in the rearward position.
You can take the whole latch assembly out and replace it, or use some type of cleaning compound and lube it up and it should work like a charm again.
