strongest tranny for the 1.8 | Ford Escort Owners Association (FEOA)
Discussion in 'Drivetrains' started by mechmunkee-j, May 31, 2007.
  1. mechmunkee-j
    mechmunkee-j New Member
    299
    phoenix arizona
    ok, i know this has been beaten to death, but what is the strongest stock transmission that will fit onto the gt/gtx? i think someone said the 323 5 speed was good, but im not sure what else besides that was mentioned. any info would help
  2. Onegimp
    Onegimp New Member
    5,792
    4
    Austin TX
    A built level ten auto tranny.
  3. wicked1706
    wicked1706 New Member
    1,491
    wichita, kansas
    uh manual... not auto.... id like to know this info too....
  4. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    the stock EGT/protege LX transmission is what you want (same thing).
    the 323 and protege DX transmissions are weaker and use a much smaller clutch.
    -jon
  5. Onegimp
    Onegimp New Member
    5,792
    4
    Austin TX
    You asked the strongest, stock up on back ups or have a custom sequential built.
  6. wicked1706
    1,491
    wichita, kansas
    lol il go with what i got then!
  7. therieldeal
    8,622
    19
    338
    Northeast CT
    run gear oil in it, redline MTL or MT90 would be some good choices.
  8. mechmunkee-j
    299
    phoenix arizona
    a custom sequential sounds... expensive. i think im going into debt just thinking about it @[email protected] id probably use the gt transmission and strengthen it as much as possible. by the way, what would be involved in strengthening a transmission...?
  9. Newfie_dan
    Newfie_dan New Member
    1,158
    Saskatoon, Canada
    kia
    the strongest tranny for our cars is the 1 from the kia sephia gs 94-97, its got a lil stouter gearing and gears for the 5spd, if you want a stronger auto buy the kit with the kevlar clutches and stronger valve body from a tranny shop.
  10. wicked1706
    1,491
    wichita, kansas
    kia sophia?!?!! does that tranny really bolt up to our 1.8????
  11. Newfie_dan
    1,158
    Saskatoon, Canada
    models
    kia sephia GS yes it does its the same engine/tranny as the gt. Its a bp engine/trans. it has the be GS model though
  12. mechmunkee-j
    299
    phoenix arizona
    you know, i remember reading that the sephia used the 1.8... i think it was on wikipedia. this is goood. very gooood...
  13. Newfie_dan
    1,158
    Saskatoon, Canada
    tranny
    good luck finding 1 at the junker or for sale though lol, I have not seen even 1 at a junker here or for sale as of yet, I would like to though as it would make some nice possibilities for a kia buildup that would shock some ppl. :p
  14. joshuh
    joshuh Guest
    219
    Some of the Kia Sportages ran the FE3 in them. Imagine taking an FE3 with the transmission, and having yourself a RWD machine :D
  15. Newfie_dan
    1,158
    Saskatoon, Canada
    fe3
    actually the fe3 swap would be wicked if you used both the engine and trans, he fe3 can take a really high amount of boost and it takes a lot of abuse. They make a great engine to build from.
  16. joshuh
    joshuh Guest
    219
    Has anyone attempted this? I once entertained the idea, but those parts are difficult to find. If anything, if I ever had an extra 'scort, I would take something like a BP(actually, why stop there with a project like this? I could use anything with the amount of required fabbing..) stick it in the back with some modified transaxles, and have a mid-engine RWD :D
  17. Newfie_dan
    1,158
    Saskatoon, Canada
    FE3
    the FE3 came in the kia sportages, but in my opinion the bpt swap makes the most sense and is in my opinion the most cost effective swap for the money. If you want to make it better then opt for a bigger turbo such as the gtr version of the bpt.
  18. brentlz
    brentlz FEOA Member
    9
    151
    Prescott, AZ
    Re: kia
    Got a blown '97 Sephia 5spd yesterday for $40...I needed a 1/2 shifter fork for my dirt toy. Not sure that t is any stronger than the EGT...case does look a bit meatier around the input shaft w/ plenty of webbing. The Kia trans had stripped reverse gears(do not mess around in reverse...those gears are 3/16" thick at best!), bad input shaft bearing, & a blown synchro (not sure what gear). Internals look the same as the EGT with the exception that the 1/2 shift fork is all steel (instead of aluminum w/ steel insert). Have to dig out my calipers and measure things while they're apart. Obvious differences I've seen so far include the external sensor plugs (reverse, neutral, and speedo), the Kia has a oil fill plug on the side of the case, and the diff has 28 splines (vs 26 on the EGT).
    Brent.
    PS: the 1.6L Kia looks to be a different beast w/ 1-piece passenger side axle.
  19. Newfie_dan
    1,158
    Saskatoon, Canada
    spehia
    has to be the GS model as I specified, the 1.6 spehia tranny is a different animal.
  20. therieldeal
    8,622
    19
    338
    Northeast CT
    the 1.6 tranny is similar to the 323 and protege dx transmission.
    brentlz, is the car you got the trans from still at the junkyard? i could really use the midshaft that bolts to the back of the block if its in good shape.
    -jon
