86 gt
My car has this problem when you first start driving down the road after you start it up 90% of the time. When you start driving, it feels as though the brakes are on, you can floor the car and it will just rev and only accelerate slowly ahead. After you get down the road about a 1/2 to a full mile, the car will stop doing this and you can feel it surge ahead as usually you have the gas pedal pushed in farther.
I can't figure out what is going on with it. I took it apart again today and re-greased the caliper pins and measured both the front rotors. Both front rotors were worn identical. Then I went into the rear and took off both drums and measured them, they were within 6 thousands of an inch of one another. Also had replaced the right rear wheel cylinder last week when I did the wheel bearings.
It does it weather or not i reverse out of the driveway and take off, or pull out, either way. I could replace the left rear wheel cylinder as that sides drum was worn more but maybe it could be the master cylinder? I'd really like some input or ideas, it sucks real bad pulling out onto the main road where people are going 50-60 and the damn car wont hardly move for about 1/2 a mile. Any help would be greatly appreciated.
Keyul
Keyul
