1 - 2 of 2 Posts
Hi guys, not a sparky so after help with regards to what i have inherited.
Got a K reg Mk5a cab, want to sort all the wiring out for the stereo properly, but its in a right state thanx to the previous owner. Have included pics to show the problem. Have done a table as best i can to explain, any more pics required please ask and i will do.
Oh my where do i start, as you can see from the pic below, i have a mess on my hands. Between the main grey cable and the main wires they are all connected together in one way or another (scary).
http://tinypic.com/r/11jopy0/4
Excuse how i word this, the metal protection that surrounds the wires inside the grey cable is connected to the brown wire attached to the top connector block.
_____________________________________________________________________________________________________________________________________________________________
There are other bits like this that would take to much explaining, more than happy to speak over the phone if anyone has the time for a more detailed explanation.
What i hope to do if possible is - can i make a fresh start and cut just after the places indicated in the photo below.
http://tinypic.com/r/kc1dfo/4
Could someone confirm that the main grey cable (1) is for the speakers and the main wires are the power and the rest (2) and what is the third cable for (3), its not the antenna as i have removed this from the display.
Is this table correct -
Out of the grey cable
Colour wire................Role
Red/yellow.................Rear speakers positive
Red/white..................Rear speakers negative
Black/white................Front speakers negative
Yellow/black...............Front speakers positive
Green/white................?????????
Green/yellow...............?????????
Brown/yellow...............?????????
Brown/white................?????????
There is also a metallic blue sheath with a red wire inside.
Appreciate any help on this.
Thanx in advance
Shortie
1 - 2 of 2 Posts
