1995 Escort LX - 1.9 SEFI Auto
Since the hot weather started, I've been having some problems starting my car. The first start of the day is easy, however when I stop the engine for about 10 minutes to an hour, it will not start. It turns over, but nothing.
So its either fuel or spark and I'm thinking its a fuel problem. So what I do and works is (most of the time) turn the key to the "On-Off-On-Off-On-Off" several times before I turn over the engine. And the fuel pump will start with a fast whine, and then as the fuel pressure builds up, it will get slower... and if I do the key sequence again, I'll hear some 'gurgling' noise from the tank.
Does anyone have any clue what the problem could be?
PS: After the engine has warmed up, when the engine is under load (especially with warmer weather) I'll hear these little ticking noises. Could it be detonation?
Thanks in advance.
Jason
Thanks in advance.
Jason
