1 - 2 of 2 Posts
I´m having a little problem with my egt 91. Sometimes (maybe twice a week, sometimes more) my car stalls. It only stalls in neutral. I noticed it only happens when i rev the motor and put it into neutral as I let the car roll to the light, the car goes down 500 rpm and it stalls. It does´nt happen often but it is still a problem i would like to fix.
Thanks in advance for your input.
Here is a little info on the car.
91 egt, 130 000 km
added a airfilter (it did it before i installed it)
_________________
[ Edited by FourDiceS04 On Date 09-17-2002 ]
I have this same problem.I found a forum on one of the escort forums on how to fix this problem has something about shorting out the pins on the computer plug under the hood and setting the idle screw and then restarting the car and the computer will fix the problem i have yet to try it but i have the print off around here somewhere
1 - 2 of 2 Posts
