hey everybody 94' 1.9 it squeaks really bad at idle on the accessory side of the motor...took serpentine off...still squeaks...took timing belt cover off took tensioner off waterpump and tensioners pulleys feel good...cam shaft bearing feels good...didn't turn the crank just yet wanted to see what the scort geniuses on here had to say! it only squeaks when it idles you give it gas and it stops until it idles again...it does sound like a bearing...what you guys think...do crank bearings go on these? motor has bout 100k on it thanks!
