1 - 11 of 11 Posts
yep!
they are the same! just the top of the zx2 stuts are a little bigger! strut wise, but springs are the same!
The bottom sleeve should be ok....
The top hat will probably need to be drilled out a tad bigger for the 3rd gen's larger strut rod.
I do know of ZX2ners that have used the Escort Coilovers and have had a problem. :? but I don't think it was anything major
Sweet because I plan on purchasing a 2000 zx2 quite shortly and why should I go and spend $400 on a set of ground control coilovers when I can get R-1's for like $80...
OMG, dude, you have got to be kidding me.
The difference between R1 and GC is NIGHT and DAY. Going out and spending the least amount of money you can is a BAD move (a riceboy move, actually), because you'll get what you pay for in the end...do yourself a favour and LEARN about the stuff you want to buy before you do it.
Being a longtime ZX2 owner, I speak from experience...your best bet is to run springs and struts, like Eibach/Tokico...that is the most durable setup...you won't be replacing struts every 1000 miles or so like you would with cheap-ass coilovers like the ones you mentioned. The ZX2 does not currently have (or will probably ever have) an adjustable strut available either (recommended for coilover use).
My 2 cents.[/quote]
I have already planned on getting tokico struts all around... and I really must disagree with your hate for the R-1 spring.. I have installed these springs on both a cavy and a neon for my friends and they seem to me to be just as good quality as any others I have seen.. neither of the two have had any problems with the springs and the only reason I say that they cost so little is because I they can be easily found on e-bay...
1 - 11 of 11 Posts
