1 - 16 of 16 Posts
BKR7E
14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, ISO Length, Projected Tip, V-Power (V-Grooved Center Electrode)
NGK's unique V-Power design directs the spark to the edge of the electrode where it develops more rapidly, this increases ignitability even in lean burn conditions. In addition the NGK V-Power plug has all the features of their traditional plugs including corrugated ribs, pure alumina silicate ceramic insulator for greater strength and better heat transfer, copper core and triple interior seal.
BKR7ES-11
14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, ISO Length, Projected Tip, .044" (1.1mm) Gap
NGK traditional plugs are constructed for longer life and optimum performance. Corrugated ribs prevent flashover. NGK uses only the purest alumina silicate in its ceramic insulator which give all NGK plugs greater strength and better heat transfer. Copper cored and triple sealed to further aid in heat removal and prevent interior leakage.
You decide.
yea im not sure about the gap ether with nitrous i heard the v tip ngk's are alittle better cause they stay cooler or cool off quicker. thanks for all your help! :)
One more ? if any one knows .. what timing should i run for nitrous? i know 10 degrees is stock some say to retard your timing but i searched and searched but cant find what timing to run with nitrous..
1 - 16 of 16 Posts
