Hello,
I have a '94 escort SW with a 1.9l motor. I am in doubt about the order which the spark plugs cables shoulb be in the motor. The firing order suppose to be 1-3-4-2, but I do not know what it means.
Every plug in the coil pack is numbered 1-2-3-4 in counterclock wise. This means that I should connect the plug No. 1 in coil pack with piston number 1 in engine, plug No. 2 in coil with piston No. 4. plug No. 3 with piston No. 4 and plug No. 4 with piston 3 or I just have to connect them matching the coil numbers with the piston number.
Pistons numbers are 1-2-3-4 viewing the car from the front, I think.
Please Advise, Thanks.
