1 - 4 of 4 Posts
Okay i just bought some splitfire platinum plugs for my 1.8 and i need to know what am i supposed to calibrate the plugs to. Then i went today and i changed my oil and i realized that both of my front outter axle boots are broken. How much do they cost and how difficult is it to repair? Any and all suggestions would be helpful.
Gracias
as to replace the boots of your axles, you need to :
1- lift the car
2- take out your tire/rim
3- unbolt either the tie-rod end and the balljoint or * more simple in my opinion* unbolt the 2 lower bolts that holds the macpherson strut in place where the strut meets the wheel spindle.
4- Unbolt the 30 mm axle nut * grease it up before you do*
5 - push on the axle towards the transmission to take all the loose off, and then work it out of the hole of the wheel spindle..
6 - you should then be able to take off the old boot and slide on the new one...
1 - 4 of 4 Posts
