So I have a list going of things I need, would like, and am possibly dreaming about...right now I am pretty broke, and don't really have any extra cash to spend (as the story always goes) but I figured I might as well post the stuff I am looking for in case someone has something that they have kicking around and they would get rid of for cheap/cost of shipping.(more**'s=more important.) here it is: -----For My ZX2 S/R *O2 sensor bung* *charcoal drivers mat* *shifter pivot bushings* 19mm maybe 21mm rsb with poly bushings and mounts(don't need drop-links)* poly bushings for stock rsb wheel spacers Mfactory LSD (or any lsd that replaces pos original spiders) *3in 3 bolt flange x2* *2 bolt flange to match zxtuner header* poly rack bushings Boot on the tranny for the shifter, and sensor/switch closest to it -----For the girlfriends ZX2 ( 98 ) *antenna wire & antenna** *crank timing gear washer (the one behind the timing gear) Iceman-found full set of charcoal interior parts(I have a set of S/R charcoal seats for it) trunk popper button Cheap key-less entry(already one wired in but its terrible and doesn't disarm half the time) small coolant tube (passenger side lower by the serp belt) cheap S/R ecu or chip for ????(have to check)-Found CWQ3 stuff to convert to newer ecu and keep ac (I need to do my research) Really cheap rds
