i want to start out with 5 psi of boost and i plan to get a 12:1 FMU. now if i raise the boost, i'd have to get bigger injectors and a A-FPR. if i keep the 12:1 FMU, what size injectors should i get and from what car will fit in the SEFI motor?
also, i know 8 psi is the max with stock ignition but if i had somethin to retard the timing, what's the max boost limit i could go for with the right injectors for the above question?
BTW, i have been searchin but i'm just a little confused.
