I'm about 4 hrs into my head swap (preemptively installing a rebuilt to avoid valve seat issues). I think I discovered the source of a mysterious rattle I've heard for a while now - the heat shield over the exhaust manifold. It is rusted out at two of the lower bolts, and I kind of just 'ripped' it out of there. My question is.. is it really necessary to put it back? Is my radiator fan going to melt or something without it there? I don't even know if I could put it back on as it is, because of the rust around the bolts (unless I used some HUGE washers!).
Also, does Autozone or one of the part chains carry the bolts for the water outlet? They were frozen solid and I snapped two of them off in the head. I'm not sure what size they are.
Lastly.. what is ideal compression for the SPI engine? I know these are higher compression than the 1.9 engines. I did a compression test before I started pulling the old head and got 190/200/190/200 PSI from left-right (cyl 1-4). Is 200 ideal? The engine has 110,600 mi on it.
Thanks.
Thanks.
