We had a good ole' north wind that blew our first real snow of the year, through every orfice in the 'Scort. I had it parked facing North and when I went to start it a couple of days ago...it started and ran like CRAP!
The total underside of the hood was FULL of snow to the point that I couldn't even see the engine. 8O
Keep in mind that I have the car in VERY GOOD mechanical condition and everything was working perfect prior to Tuesday morning. I drove it to work (very underpowered and top speed of 50 mph) and when I got home last night, drove it into the shop and parked it for the night. I went outside this morning to take a closer look at things and after removing the timing belt cover, I checked the timing marks. The belt, water pump, and tensioner have less than 50K on the combo. It had jumped two teeth on the belt! :x After removing the belt and having a closer look at it, I determined it needed replacement. Also I'm replacing the serpentine belt and both front sway bar links as one of them was broken off as well.
The only thing I can thing of is that snow must have found its' way in behind the cover to the point where when I started it... things moved. I have never had this problem before and hope to not have it again.
I should have it back together tonight after work but what a royal pain in the a$$...
Just venting
Dave
Just venting
Dave
