Smoke again | Ford Escort Owners Association (FEOA)
Smoke again
Discussion in 'Tech & Repair' started by black93scort, Nov 5, 2004.
  1. black93scort
    black93scort Guest
    482
    Okay I have 2nd gen and when im work at night ill go outside and listen to music and I notice that my car blows an awful lot of white smoke. I know some cars do but it just seems like a lot to me. It is cold though maybe 50s or something. I still think I may have cracked my head or bent a valve so could this be a sign of that or maybe something else?
  2. escortlx96
    escortlx96 Guest
    680
    You might have a bad head gasket.Check to see if coolant is leaking from the head.
  3. black93scort
    black93scort Guest
    482
    It only does it when its cold though. and shouldnt there be other problems with bad head gasket, like bad idle and such.
  4. escortlx96
    escortlx96 Guest
    680
    When is the last time you did an oil change?I remember having white smoke when I put too much oil in and my head gasket going.
  5. SgtRauksauff
    SgtRauksauff New Member
    1,669
    Wisconsin, USA
    is it blowing white smoke (steam) after it's fully warmed up and has been driven for a while (15-20 minutes) at highway speed?
    It's probably just all the moisture inside the exhaust tract that condenses when you shut the car off. it gets hot and turns to steam and comes out the tailpipe the next time you run the car.
    --sarge
  6. highanddry
    highanddry Guest
    8,446
    5
    Keep a close eye on your coolant level. I check all my fluid levels once a week. If the coolant level in the overflow reservoir is stable, obviously you have nothing to worry about. You can have a head gasket problem without noticing any engine performance problems (for a while), but at certain times of the year (spring and fall) you will notice more white exhaust due to the condensation issue that Sarge references.
  7. Ignatz
    Ignatz Guest
    212
    If it's antifreeze you should be able to smell it when you start it up. Just start it up and walk around the car and check for a "sweet" smell.
  8. TitoElSpicco
    TitoElSpicco Guest
    1,078
    Yes, it's perfectly normal. :)
