will shifters off of a 1.9 five speed fit on a gt
I am confused, do you have a GT one to sight against a LX one? It was years ago, but I do recall having to take the assembly back out to swap the one rod...my experience nothing more.fast_five_oh said:not to say your wrong low...but y in the hell would the ones i got have matched up exactly..i mean same bends an everything...
also love the wheels you got
yea i had the lx one off car an the gt was still on the car..the gt car was on a lift so i could get under it..LOWETGT said:I am confused, do you have a GT one to sight against a LX one? It was years ago, but I do recall having to take the assembly back out to swap the one rod...my experience nothing more.fast_five_oh said:not to say your wrong low...but y in the hell would the ones i got have matched up exactly..i mean same bends an everything...
Thanks, they're 17" Enkei RS5.
i am converting my automatic transmission to a manual but i have a few one nines in the yard that i can take the shifters off so i think thats what im gonna doLOWETGT said:I believe that the shifter rod that connect to the transmission to input gear selection is different from the LX to the GT. The input location is different so when I picked up entire LX shifter assembly to fix my "dropped" issue, I had to reuse the GT's shift control rod. The stabilizer bar is in the same location. That's my experience, Why are you changing yours, I assume it dropped as well. I prevented mine from dropping when I had the trans out and installed the short throw shifter. I drilled through both plates near the stabilizer rod and bolted them together. No more dropping!
