1 - 13 of 13 Posts
· Premium Member
Cutting it won´t make it a true short shifter. It needs to be lengthened on the bottom half for it to be a real shorter throw. Pacesetter and B&M both make real short shifters for the scorts.
well if you think about it, you could just take off the head and boot and shift your car from the base of the shifter, you´re still shifting the same distance, it´ll just "feel" shorter because you´re not at the head of the shifter. I thought with most shifters you change out the linkage and the rod itself, or am I assuming something and being wrong? :)
Yeah, a "true" short shifter would require a new linkage. It all has to do with where the axis of pivot is.
I personally like the feel of the stock shifter. The length and force required to shift is imo really nice. Maybe not the best looking shifter, but I never feel like the time it takes me to shift gears is too slow...
here´s what I do for a really fast shift:
put my hand on the shifter and put light pressure in the straight line direction of the next gear I´m going into.
drop the throttle at the same time you´re throwing in the clutch. when you throw in the clutch, use your ankle instead of your whole leg. this will make things a bit quicker. also, make sure that you let off the throttle and push in the clutch at the same time so you don´t dead-throttle it and then buckle up the wheels.
then when the clutch goes in, you´re already pushing it a little into the next gear, and the fact that you´re dropping the power to the wheels will pop it out of gear and it almost shifts itself. then once you´re in gear just drop the cluch about 3/4 of the way and then wean in the throttle at the same rate as the last 1/4 of the clutch stroke and you´re golden.
well i think one of my synchros is bad because trying to put it in second gear after hitting 7000 rpms in a sprint for the redline is like trying to shove a square peg in a round hole sometimes... it just doesn´t want to go in without an excess of force. I´d like to put a short shifter and rebuild my transmission as well. but that´d cost a lot. and most of my attention is going into my engine. did I just rhyme?? wow.
1 - 13 of 13 Posts
