When I removed my head, I noticed there was some kind of white sealant around where the intake manifold meets the head and blocks off the coolant passage there. It looks like it was applied to both sides of the intake manifold gasket, presumably to prevent coolant leakage around that seal. Is this strictly necessary upon reinstallation of the head? If so, what kind of sealant should be used for this?
Also, what do you guys use as a good thread sealer for the head bolts that go into the water jacket?
