Saving a 91 EGT | Page 2 | Ford Escort Owners Association (FEOA)
Saving a 91 EGT
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by kTaLgsTo, Feb 11, 2020.
  1. kTaLgsTo
    kTaLgsTo FEOA Member
    19
    17
    Current progress...
    [​IMG]
    [​IMG]
    Emailed rockauto about pump snaffu, they admitted they had a catalog error and they don't actually sell an oil pump for my specific crank... They refunded me and said I could keep the oil pump.
    Took the oil pan back off, pulled the pump, tried to see if I could swap gears but this is a no-go.
    [​IMG]
    [​IMG]
    The tolerances on the old pump still look pretty good, I am going to measure them and compare to spec in the book.
    Anybody know if the big nose crank and small nose crank oil pumps can interchange springs?? I figure the spring and piston is probably also a high wear item so I was going to swap them over from the new pump... But if they are not the same spring rate, I do not want to increase/decrease oil pressure to a catastrophic level.... If anybody knows if the springs are the same rate this would be cool... I know they do fit as I have already swapped without any visual issues...
  2. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,379
    1,096
    Vancouver Island, Canada
    Although they are often replaced, oil pumps almost always show very little wear. They are always bathed in oil, after all.
  3. kTaLgsTo
    19
    17
    Issues over and over again from rockauto, they only sent me 15 lifters....
    Head is on, was going to install cams but this will have to wait, I put in a case and waiting on reply... Over a 6.00 lifter.
    Anybody know how much meat I can take off the head and block before I have to think about adjusting the timing?? Took .012 off the head and .007 off the block, so I am at 19 thousandths total...
  4. Joey_Twowagons
    2,379
    1,096
    Be careful with the silicone. I have inspected two engines that had been wrecked by it. Excess silicone can be squeezed out as drops inside the engine. These drops can fall into the oil, and can deform enough to get through the oil pickup screen.
    One ruined engine had the pressure relief valve jammed open by a silicone blob, while the other had a piece blocking an oil passage in the crankshaft.
  5. kTaLgsTo
    19
    17
    Well, back together and getting no spark.
    I have checked:
    Timing, again and again and again.
    I verified voltage to the coil and the ICM
    Verified voltage to the distributor
    Checked grounds to the ignition harness, added extra grounding just in case
    Have plenty of fuel.
    Replaced the coil, and ICM with junkyard parts with no change.
    ECU seems to be okay because I get check engine and warning lights with key on.
    The distributor is brand new off rock auto, and I am wondering if it is faulty. It struggles to turn over with distributor plugged in, like timing is wrong. If I unplug distributor harness it turns over much easier.
  6. fastkort94az
    fastkort94az Well-Known Member
    61
    Phoenix, Arizona
    Pretty cool to see the rebuild process here. I hope that after all your efforts, you get this thing back on the road.
  7. kTaLgsTo
    19
    17
    I've got 300 miles on it so far, I quit updating because it seemed nobody was really on here anymore. No spark ended up being a DOA Distributor from Rock Auto.
    I replaced the brakes, ball joints, tie rods, and wheel bearings. It drives pretty good now, first tank was 22mpg mixed which seems low. But I also had it timed to 0*, I bumped it up to 10* so we will see what that does, it already feels better.
  8. Casanova23
    Casanova23 FEOA Member
    116
    266
    Good job on getting it going @kTaLgsTo!! There's a Facebook group set up for the message forum thats pretty active and most guys nowadays just use that. Figured id give you a heads up if you didnt already know. How's it looking now?
  9. kTaLgsTo
    19
    17
    It's back in my shop waiting on a new brake caliper. Rock auto sent me a faulty one... One of the seals on it blew out so I put in a case with them. Otherwise it runs great. I've never had so many problems with parts off rock auto in my 20 years buying from them as I've had in these last three months
  10. krux303
    krux303 FEOA Member
    53
    11
    8
    Dont worry I was in the same boat with Autozone calipers. Only reason went through autozone is based on lifetime for calipers. Ebrake didnt work and seals were leaking.
    Sent from my LG-H872 using Tapatalk
