Saving a 91 EGT | Ford Escort Owners Association (FEOA)
Saving a 91 EGT
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by kTaLgsTo, Feb 11, 2020.
  1. kTaLgsTo
    kTaLgsTo FEOA Member
    11
    13
    Hey all, I picked up a 91 escort gt left for dead.
    I have some questions on this thing, but first I'll introduce myself.
    My name is Luke, I've went through life buying what I consider neat cars, fixing them up and then selling them for a loss. I always wanted to lose money on an escort gt but they've been hard to find most of my life until now.
    This car has sat for a couple years, wouldn't run and I have very little info on it's past.
    I picked it up and did a compression check only to see it has 0, 35, 90, 0. Now for my first question, is there a special procedure on these for a compression check? I just pulled the fuel fuse and went at it.
    After I ran the test I checked the timing belt, it is brand new, so later this week I am going to put it at tdc and check the job was done right.
    My last question is how likely are these cars to have head gasket issues?
    I know I'm getting fuel as the spark plugs reek of it, and I'm getting spark as well.
    Thanks for reading!!!
    If timing looks good I'll be pulling the whole motor and having some fun.
    zzyzzx and Rjtheracer99 like this.
  2. pextor
    pextor Moderator Staff Member
    5,861
    756
    Lancaster, pa
    Definitely start with timing. Hopefully that's it. The 1.8 BP motor is generally known for it's reliability.
  3. kTaLgsTo
    11
    13
    Timing was good, I pulled the motor yesterday, if I had known it was such a pain in the ass to pull the motor without the trans then I would have just pulled the whole set.
    Either way, this helped me determine what all needs replaced... Plus I snapped a fuel line because it got hung up on the intake when pulling... So now I have to source one of those. Onward to cracking her open and finding the compression problem!
  4. kTaLgsTo
    11
    13
    All four pistons were cracked, missing pieces, this motor is a mess! How does all four pistons take a hit like that?
    Machine shop said block looks good, crank also looks good. So I ordered pistons and we're going head first into this baby!
    zzyzzx and Joey_Twowagons like this.
  5. zzyzzx
    14,769
    1,111
    Pics please!!!
  6. kTaLgsTo
    11
    13
    Dump incoming
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Cylinder 4
    [​IMG]
    Cylinder 3
    [​IMG]
    Cylinder 2
    [​IMG]
    Cylinder 1
    [​IMG]
    [​IMG]
    The worst bearing
    [​IMG]
  7. zzyzzx
    14,769
    1,111
    I was expecting more carnage, but this would explain why the engine block itself is still good. Thanks for the pics! That car should clean up nicely!
  8. kTaLgsTo
    11
    13
    I am hoping so, the machine shop said it looks like it saw many miles with a blown head gasket.
    The block needed decked, which means the head probably does too.
    I'll be bringing the head in next week along with the rods to verify they are still true.
  9. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,163
    952
    363
    Vancouver Island, Canada
    What the heck caused that? Detonation?
  10. kTaLgsTo
    11
    13
    I had three theories:
    Over heating, but this is probably ruled out by the minimal block and piston scoring.
    Water ingestion, which had me worried because then the rods could be bent.
    Or timing, the crank was off two teeth, so maybe this caused detonation.
  11. kTaLgsTo
    11
    13
    Picked up the manual...
    [​IMG]
    [​IMG]
    Found one of the Rods was put in backwards from the factory, which really shouldn't matter, but I thought it was an oddity... Guess I'll keep it that way since it's ran 100k+ miles this way...
    [​IMG]
    [​IMG]
    Installed some Chinese pistons
    [​IMG]
  12. kTaLgsTo
    11
    13
    Crank is in!!!
    [​IMG]
    [​IMG]
    austin86 and zzyzzx like this.
  13. Joey_Twowagons
    2,163
    952
    363
    The more I think about the pistons, the more it doesn't make sense. If those chunks of pistons broke off in a running engine, how did they get out? Did they wiggle around the exhaust valves and sneak out as they were bouncing around, somehow not getting caught between the piston top and cylinder head surface?
    Then the backwards installed con rod. I would say some monkey has taken apart the engine, damaged the pistons somehow and reassembled it improperly, not surprisingly.
    kTaLgsTo likes this.
  14. kTaLgsTo
    11
    13
    Yeah I suppose there could be some shenanigans with this thing.
    The piston damage really was quite strange, either way its all getting sorted. Hoping to be back on the road soon enough.
  15. kTaLgsTo
    11
    13
    I thought I had already added these pictures, but I guess not... Check out how beat these things were....
    [​IMG]
    [​IMG]
    Also, I have some guy trying to sell me a low mileage MTX-III manual trans, is this what is in the escort currently? He claims it's less than 20k miles, but I admittedly do not know what the trans is in these cars...
  16. Joey_Twowagons
    2,163
    952
    363
    Good to see the rebuild process. With the new pictures' side views, the pistons can be seen to have taken quite a beating, so maybe the chunks of piston were indeed pulverized and passed out the exhaust.
    What does the matching combustion chamber surface look like?
    Also, I am curious to know what the deck clearance is with the new pistons. Aftermarket piston makers used to have the terrible practice of "de-stroking" oversize pistons (reducing compression height) to compensate for the slight increase of compression ratio due to the larger piston area. I have also heard they did this in anticipation of skimming the deck surface during the rebuild.
    Anyways, the practice used to be to "de-stroke" the pistons by the same amount as the diameter was increased. So the top of a 0.020" (0.50mm) over size piston would be 0.020" lower in the bore. Which, ironically, actually increases the tendency of detonation.
  17. kTaLgsTo
    11
    13
    This is the worst cylinder after hone:
    [​IMG]
    Machine shop said all cylinders were still true, I had expressed to them I didn't want to bore unless needed. I didn't think this was too bad being the worst of them so std pistons were used, should hear back on the head this next week. Just one look at the valves and he said yeah those need replaced, they don't close cleanly anymore. He believes they took quite a beating and was impressed by the overall good condition of the block because someone must have just beat this thing to heck.
    I'll keep reporting back on progress...
