I'm new here and this is my first post. My other car is an SVT Contour.
Our 2000 ZX-2 has an electrical issue that I hope someone can help me with. When the running/park lights are turned on, the tail fuse blows. The headlights, brake lights, turn signals, and 4-way flashers work. I've replaced the multifunction switch and what I thought was the parklamp relay. The white/black wire from the fuse box appears to go to more then one relay.
1) Is there a way to test the relays to determine the correct parklamp relay or a malfunctioning relay?
2) What else could it be if not the parklamp relay or multifunction switch?
