Engine - Rough Running, Need 2nd Opinion | Ford Escort Owners Association (FEOA)
Engine Rough Running, Need 2nd Opinion
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by russix, Nov 19, 2020.
  1. russix
    russix FEOA Member
    20
    7
    153
    While driving I'm experiencing intermittent roughness and it wants to stall. In this video you see me revving the engine a few times trying to recreate the issue. At about 1:00 it occurs, you can hear the exhaust sound deepen, the engine starts running rough and it begins to stall. Seeking input, thank you.
  2. denisond3
    10,195
    2,871
    While its hard to tell the sound of a recording (due to the dynamics/placement of the small microphones, etc), the sound I heard included what seemed to be some rough running - at all speeds and throughout the video. When you were revving it up, I would have expected to have it sound much smoother. Again, not easy to tell. I could suspect an injector that wasnt working right, or was working intermittently. Each injector should have 12 volts to one of its wires, the other wire gets grounded by the PCM to make it fire.
    Have you done a compression test? Do the plugs all look dry and near white?
  3. pextor
    pextor Moderator Staff Member
    6,011
    842
    Lancaster, pa
    Is the check engine light on?
    The first thing I would do is replace the fuel filter and inspect/replace the air filter.
  4. russix
    russix FEOA Member
    20
    7
    153
    CEL is not on, gonna check for a bad intake manifold gasket tomorrow.
  5. russix
    russix FEOA Member
    20
    7
    153
    My timing belt is flapping like a black shroud in the wind. Will replace now. Thank you.
  6. pextor
    6,011
    842
    Lancaster, pa
    When my tensioner failed, my car made a different sound:
  7. zzyzzx
    15,244
    1,237
    Replace the tensioner too!!!
  8. denisond3
    10,195
    2,871
    I had that same noise when the tensioner in my 93LX let the belt get loose enough to slap on the timing belt cover. I replaced the tensioner. I must not have gotten the old one torqued properly.
  9. Joshua Schwenker
    Joshua Schwenker FEOA Member
    29
    5
    South Carolina
    Heck, get the kit that includes the pulleys, both idler and tensioner, also make sure you get one with a water pump so you can go and do that too mine also came with seals for the crankshaft ,the cams and the WP I believe
  10. russix
    russix FEOA Member
    20
    7
    153
    Anyone ever tried to run the motor with the valve cover off? I think I have a bad valve tappet.
  11. denisond3
    10,195
    2,871
    You can run the engine with the valve cover off. Expect some misty oil spattering around though; less if you warm up the engine so its at idle speed.
  12. russix
    russix FEOA Member
    20
    7
    153
    I replaced a bad lifter, but it still runs rough and sounds like a backfire through the intake. And I have this ticking sound: Injectors or something else?
    Compression test: #1 185 #2 180 #3 185 #4 190
  13. russix
    russix FEOA Member
    20
    7
    153
    So I did an Intake Manifold Vacuum test. It warms up with a pretty steady vacuum(no noise). Then the noise will start and the vacuum gauge will flutter from normal down to zero. I think I've gathered enough data to call this a dropping valve seat and will pull the head off before it comes completely free and destroys the rest of the engine. Thank you everyone for your input.
  14. zzyzzx
    15,244
    1,237
    If that is the case, IIRC this would be the first time anyone caught a dropped valve seat before it actually happened. So keep us informed.
    How many miles are on this engine?
