I have a 1999 ZX2 DOHC automatic. It has been idling very rough. It sputters and stalls when I slow to a stop
then runs ok when I get it rolling :? . The check engine light is on so I had AutoZone pull the code and it was P0171 "System to lean". I thought that fuel delivery would be a good place to start so I replaced the fuel filter first. Nothing changed. I was getting ready to have the fuel pump done but I found that the car still had good acceleration after it would get going so I abandoned the fuel delivery track.
I just checked the throttle body and it looked clean. I have some cleaner but have not seen a reason to use it. I have read the forums here and now I am thinking I should look at the MAP sensor. These are expensive and I do not know how to test or evaluate the sensor. I was also thinking of other things like the idle air control valve and PVC valve.
Doe anyone have any thoughts on this?
