AIC P1506
Okay all you grease monkeys,
I have a P1506 code which is the AIC valve error, I replaced it with a new one and I was told to drive on interstate at about 60 so it can reset itself. I have done that, with still no avail. When I installed the new one, i disconnected the neg battery terminal and followed directions. After I replaced it, another code came up which was a low input on my MAF sensor. It was running rough. I replaced that and it seemed to fix everything, except for the P1506 code. It idles pretty decent, but I have noticed when I change direction of the air flow ( vents, floor, defrost etc,) it idles differently, but seems to recover quickly. Any help would be appreciated. I'm getting ready to bore out my cup holders, cause I'm tired of spilling coffee in the mornings, terrible design! Thanks again. Dskarl29
