1 - 5 of 5 Posts
On my mother´s 95 LX wagon, the Yokohama Avid Touring tires need to be rotated. I need a complete description on how to rotate the tires and the proper method of tightening the lug nuts once they are rotated.
Well,
When rotating tires on a front drive vehicle, without directional tires, its easiest to do it thisway
O LF O RF
O LR O RR
Take your Left front tire, swap it with your right rear. Take your Right front and swap it with Left rear. Easy enough.
For lugs I don´t know the torque spec. but there is a torquing pattern. Here goes another drawing.
o
l
o------O------o
l
o
Just tighten the lugs not to spec, in a cris cross pattern, then when they are all tight, torque them in the same manner. Hopefully this will help you.
1 - 5 of 5 Posts
