I have a 97 LX and the rocker panels on both sides are pretty much done.
There several areas that have massive rusted out holes all along the underside of the car. Pushing with your finger on an area that looks iffy, results in a collapse of the metal in, and a new hole. This is from one wheel well to another on both sides.
Basically I'm looking at removing both completely up to the point where it curves up towards the door. If I don't remove them, they will just flake off as rust over the next year or so anyways.
What's the easiest solution to replace them with?
I will post pics if clarification is needed.
