Definitions of rims on the Web:
fancy and often aftermarket wheels for a car or SUV esp. those which are very shinny and have large holes revealing the brake rotor
en.wiktionary.org/wiki/rims
rim - the shape of a raised edge of a more or less circular object
rim - (basketball) the hoop from which the net is suspended; "the ball hit the rim and bounced off"
rim - run around the rim of; "Sugar rimmed the dessert plate"
rim - the outer part of a wheel to which the tire is attached
rim - furnish with a rim; "rim a hat"
rim - flange: a projection used for strength or for attaching to another object
rim - brim: the top edge of a vessel or other container
wordnetweb.princeton.edu/perl/webwn
Rim: A Novel of Virtual Reality, often shortened to Rim (1994), was Alexander Besher's first novel. Set in the near future where virtual reality has dominated the economy and popular culture (much like today's internet), commercial space travel is commonplace, and orbiting space hotels surpass ...
en.wikipedia.org/wiki/Rim_(novel)
The rim of a crater is the part that extends above the height of the local surface, usually in a circular or elliptical pattern. In a more specific sense, the rim may refer to the circular or elliptical edge that represents the uppermost tip of this raised portion. ...
en.wikipedia.org/wiki/Rim_(craters)
The rim of a coin is the sharp circular (or otherwise shaped) edge which surrounds the coin design.
en.wikipedia.org/wiki/Rim_(coin)
A rim is an external flange that is machined, cast, molded, stamped or pressed around the bottom of a firearms cartridge. The rim may serve a number of purposes, the most common being as place for the extractor to engage. ...
en.wikipedia.org/wiki/Rim_(firearms)
RIM - Research In Motion Limited (RIM) (, ) is a Canadian wireless device company best known as the developer of the BlackBerry smartphone.
en.wikipedia.org/wiki/RIM_(Research_In_Motion
rim - An edge around something, especially when circular; wheel rim; (slang) to lick the anus of a partner as part of the sexual act
rim - Read-In Mode
www.vmlabs.com/stonline/press/news/glossary/r.htm
