The fallowing calculators will help you pick the correct size injector for your application.
This calculator will calculate what size injector you require based on number of Injectors, Brake Specific Fuel Consumption, Duty Cycle desired, and approximated HP.
Also it can be used to tell you how much HP a specific flow rate injector will support based on number of Injectors, Brake Specific Fuel Consumption, Duty Cycle desired, and flow rate.
Injector Calculator 1
This injector calculator will perform flow conversions for cc's to lbs/hr or lbs/hr to cc's. It also will do the first function of the above calculator as well as compute the flow change of an injector from added fuel pressure.
Injector Calculator 2
