Yeah that. The bottom of the speedo sensor is also the full indicator. Any manual will show what 'full' looks likemadmatt2024 said:I thought the 2nd gen transmissions didn't have a fill plug. You have to fill them from the speedo sensor.
On the contrary. Ford 5-speeds use ATF fluid. There are other threads on this. You could always read the manual.silverton said:Manual transmissions use gear oil. Automatics use Dexron, Dexron fluid is hydraulic, which 5spd transmissions are not.
nightfire said:5. Measure out approximately 3 liters (3.3 qts) of Dexron III/Mercon ATF fluid or 80/90 gear oil
Oh, and start looking for a new speedo sender right now to save your self some time. Yours is seezed, and you'll break the top plastic peice off trying to get it out.gnx547 said:How many quarts does the 5 speed manual take? And where is the fill port?
I have'nt broke one my self. But being on Escort forums for as long as I have, you run into it all the time.95EscortDriver said:Not everyone breaks off seised ones Jeff! The fluid in my Red car hadn't been checked in 10 years when I got it. Unbolted it, took a pair of pliers, wiggled it left and right to unsieze the metal, then took a pair of vice grips and attched them snug to the metal part and pried upward gently til it popped loose 8O Thought you would try that. Did it all from the top.
