escortrio said:watch out the thermostat bolts break easily. sometimes they build up alot of rust.
This happened on my 95 and I was lucky the Ford tech had a drawerful of used bolts. The bolts are not available through Ford parts any more. There is a fairly good chance one or more bolts will break and depending on where the break is, they may have to be drilled out. I would consider having a Ford dealership do this work, because they do it all the time.
I think a thread locker would serve to make them more likely to break off in the future...denisond3 said:And when you put the bolts back in, be sure to coat them either with an antisieze compound, or thread locker or a little grease. Also scrape the head if there is any buildup of corrosion, to get down to real aluminum for the gasket to seal to.
That is what I'm afraid of :x My escort has 117,000 miles on it and I don't know if the previous owner replaced the thermostat, should I just leave it?escortrio said:watch out the thermostat bolts break easily. sometimes they build up alot of rust.
helps to take the coil pack bracket off to get to one of the bolts
I thought that was the purpose of the anti-seize compound.madmatt2024 said:Not necessarily. The thread locker acts like a barrier between the threaded hole and the bolt. Moisture can't get between the threads with the locker on them so they won't rust in place.
