1 - 11 of 11 Posts
I recently found out that one of my springs on my 3rd gen is broken and have decided to look for a new suspension setup.
does anyone have any suggestions of what companies are better and are there any setups that come as strut/spring combos?
I have heard of the Tokico S/R struts for the ZX2 but haven't seen any strut/spring combo deals.
I'm not looking to have track ready suspension, all I need is a replacement, but I would prefer a 1 in. drop from stock.
PLEASE HELP!!!
1998 ZX2
The S/R struts are tuned for the Eibach springs though you can use any other springs with them if you want. The factory struts have longer shafts than the S/R ones so if you put drop springs on them they will bottom out and in a short time blow.
do the S/R struts come with spring bushings?
i have no idea what they are but my dad says that they are important to have when replacing struts.
i have looked at the eibach pro-kit springs and am under the impression that they work with the S/R struts.
but seriously, spring bushings, need with the eibach's and S/R's or no?
i would appreciate a response from someone who has used this combo :!:
how bout adjustable coil over springs on my stock struts?
1998 ZX2
The problem with the stock struts is the shafts are to long. If you put lowering springs or coil-overs on the stock struts the shaft will bottom out inside the strut and damage them. The S/R struts have shorter shafts and are designed for lowering spring. They are actually matched to the Eibach springs but you can use any with them.
if i wanted to not use adjusting perches for the coil overs to give it a 4 inch drop, how well will the s/r struts do? will the high performance struts be needed for this?
1 - 11 of 11 Posts
