1 - 7 of 7 Posts
1998 ZX2
Provided the housing bolts don't break off its fairly straightforward. You should probably replace the thermostat while your in there as it is only $6. Drain the radiator before you do it. Now is also a good time to replace your coolant as well.
1998 ZX2
Um, what ever one the parts store gives you. You could spend the extra money and get one from Ford if you wanted but it probably won't make much difference.
1 - 7 of 7 Posts
