Removing the passenger side air bag | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by gnx547, Oct 18, 2011.
  1. gnx547
    gnx547 FEOA Member
    428
    168
    I'm getting a rattling sound coming from the passenger side dash. I'm thinking there might be a loose screw inside the pass side dash. How does the passenger side air bag come off? Does it come off by slowly prying on it?
  2. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    open the glove box, push the sides in to open it past it's stops. Remove the 2 nuts holding it in place. Look up from the underside, and you will see the bolts that hold the air bag in. Remove them and it will slide out the front and unplug.
  3. Swift
    Swift FEOA Donator
    482
    95
    278
    make sure you disconnect the battery before you go unplugging it, there have been cases of them activating when they had power
  4. zzyzzx
    14,876
    1,149
    I'm sure that would work, but it would be easier just to pull the two fuses used by the air bag system.
