ok, i know i posted this in the 1.9 section but i decided to start a new thread of the subject here for u turbo guru's. basically if the 1.9 can handle 8 psi before pinging becomes a problem with the stock ignition set at 10 degrees with the OAP connected. if removing the plug retard the timing by 3 degrees, how much more boost would it be able to handle?
