I can´t get it off the exhaust manifold. It´s the stock OEM o2 sensor (I think) and I really hope it´s not welded onto the manifold.
I haven´t been able to get that much torque on it because it´s at such a godawful weirdass angle and the crossmember and radiator are both in the way... argh. what tool should I use? How do I get it off?
Also, how do I properly probe the O2 sensor (WITHOUT SHORTING IT) to measure the output voltage? I need to tune the idle mix because I put on the RX-7 VAF. Thx.
