1 - 8 of 8 Posts
take off the brake calipre to start.
Then basically get a big rubber mallet...or a sledge with a 2x4 board....and beat the crap out of the thing
possible some wd-40 or pb blaster around the rusted areas...although if you are planning on reusing the rotors make sure you use soem brake cleaner to clean the parts before reassembly
or you can do it the easy way and run a bolt into the threaded hole thats between 2 of the studs and tighten it until it pushes the rotor away from the hub
drums usually have a threaded hole too
If they're really rust on, you'll just end up stripping that thread :x . So then you'll tap a bigger hole and it'll strip too :evil: . Then you'll bang the snot out of it till it comes off.
drive the studs out a little, this gives them some play room, then beat the crap out of the rotor until it comes off. Make sure to put a nut on the end of the stud so you dont chew the threads up. I had a rotor on the front of my LX that wouldn't come off.... I beat and beat and beat on it, but it slipped right off when I drove the studs back 1/2 inch.
hell once i got my calipers off i grabbed a ball pine hammer and gave it hell... they came off -=D
yeah first off good luck with the calipers.... then just start beating the rotor... thats what i had to do on meany car's that i've worked on... nice rubber mallot hammer or when im replacing the rotors a regular nail hammer or big rocker or what ever hell i feel like beating the rotor with :twisted:
1 - 8 of 8 Posts
