1 - 2 of 2 Posts
I recently purchased a '92 Escort GT with a friend as a rallycross car. The a/c condensor is already gone and I'm wanting to remove the rest of the system. I know the compressor and lines can go but is there anything else that can be removed?
Here are all the parts:
Compressor, compressor block bracket, high and low pressure lines (along with the drier canister and pressure switches and stuff), condenser, evaporator core (involves ripping the dash apart), and that's about it. If you REALLY wanted to remove the entire A/C system and save every last gram, you could even take out the wires in the harness and desolder any unnecessary electronics in the ECU, but other than that... that's everything.
1 - 2 of 2 Posts
