need to swap the injectors to see if its the reason my cylinder 2 misfire is due to the injector. That said, i went to junkyard to see how to pull the inkectors. Removed some bolts, unclipped the two clips on each side of fuel rail, and gained some wiggle room but on my own personal car dont feel safe yanking on it like that. Do i need to pull each side out of the clip things on each side? Are those the things i need "ford fuel line removal tool" for? Doing this weekend so want to have everything i need.
Thanks
Dale
Thanks
Dale
