My camshaft senor difinitely appears to have two mounting screws. Wish the bolts were metic heads. Wife would be much better. Thank you for you infor and response!
I'm not sure how your wife is involved here, but we can leave that for another day.
You originally started this thread with the words
camshaft sensor and
code 214.
Those two terms in fact go together, and refer to something bolted into the HEAD with ONE SINGLE fastener.
Then, you bring the timing belt into the discussion, which is nowhere near the
camshaft sensor, but IS near the
crankshaft sensor that
IS attached with two fasteners.
Here are my new recommendations, based on this additional information:
1. If the timing belt is anywhere near that old, you should contact the Guinness Book of World Records (and also replace the timing belt and water pump).
2. It is not necessary to remove the
crankshaft sensor to accomplish these things.
3. Replacing the
crankshaft sensor will ALSO have NO bearing on a code 214, since that code is related to the
camshaft sensor, held in the head with one bolt.
4. Reread 2. and 3. above - there is NO REASON for you to remove the
crankshaft sensor, and no need to worry about the two funky fasteners.
5. For help on code 214, read my original response, and perhaps do a site search of "214".
