Remove broken head bolt | Ford Escort Owners Association (FEOA)
Discussion in 'Tech & Repair' started by russix, Sep 28, 2019.
  1. russix
    russix FEOA Member
    14
    5
    153
    I pulled the head and broke two head bolts in the process. Seems like I have plenty of real estate to work with. I have a map torch, freeze off, wax and bolt extractors. I am curious if anyone has any suggestions here. Also this silver paste substance that is spread everywhere, is that a tell-tale sign of a block sealer used at one point?
  2. zzyzzx
    15,003
    1,167
    I used a small pipe wrench to grab the protruding part. It came right out.
    Note: Use the Mahle aftermarket head gasket, not Fel-Pro.
    ShakeZilla19 likes this.
  3. zzyzzx
    15,003
    1,167
  4. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,164
    659
    263
    I heated the side of the block near the broken bolt and grabbed the bolt with big vise grips. The silver paste is what is left of your old head gasket. The original head gaskets on about 2000 and older are similar to silver exhaust gaskets. They flake apart after a few heat cycles which is normal.
  5. zzyzzx
    15,003
    1,167
    That thought occurred to me as well, but I noticed that it was only in the area where the gasket was leaking, and was wondering about that.
    Yes, we know that there was a leak where the silver paste is, even though the OP never stated such.
  6. russix
    russix FEOA Member
    14
    5
    153
    Gonna weld a nut on. Seems like block sealer in the coolant passages.
  7. zzyzzx
    15,003
    1,167
    Try it the easy way first. I've seen numerous accounts here and on YouTube where they came out easily like mine did.
    denisond3 likes this.
  8. russix
    russix FEOA Member
    14
    5
    153
    Done!
    austin86 likes this.
  9. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,343
    1,068
    Vancouver Island, Canada
    Good to hear!
  10. zzyzzx
    15,003
    1,167
    What method did you use?
  11. Joey_Twowagons
    2,343
    1,068
    Looks like he welded nuts to the protruding pieces of the broken bolts.
    Bonus - now there's a couple new, short bolts!
  12. marclar
    8,882
    505
    seabeck WA
    make sure to run a tap down those holes with the damaged bolts.. just to verify thread shape and depth.
  13. russix
    russix FEOA Member
    14
    5
    153
    I put it back together and I can say, wow that made a huge difference. Next time, I'm gonna use an impact wrench to loosen the head bolts a little, then use the breaker bar to untorque them in order. Thanks everyone!
  14. 88ESCORTV6
    1,239
    235
    313
    Hawkesbury Ontario
    very nice work for a noob. :p
  15. zzyzzx
    15,003
    1,167
    The thing is, with this car for at least the timing belt or head gasket, all you go to do is watch a bunch of YouTube videos for other cars, then watch the ones for an Escort. After seeing how much harder it is to do on other cars, you will think it's easy to do on an Escort. So easy I actually reinstalled my timing belt that had 25K miles in it when I did my head gasket. After all, it's not like it's that hard to change out just the belt.
  16. austin86
    688
    208
    58
    Ohio
    Escorts are nothing like a euro car with a big engine crammed in a small car. Ohh good lord I recall what I went thought with my Audi B5 S4. Loved the car, but never again will I own one.
    EDIT:
    I had to pull the front end of the car off to change the water pump and belts.
