1 - 4 of 4 Posts
Will the 270 piece sets I see widely available be sufficient?
As long as it's HNBR should I care about the color? Some are purple.
Is this a thing where I would potentially need a metric and SAE sizes?
If It matters, I intend to use these on the following vehicles:
1995 Escort LX
1999 Oldsmobile Alero V6
2000 Camry 5SFE
And possible at some point:
2000 Dodge Dakota 3.9L (currently A/C removed on this vehicle).
2011 Ford Edge 3.5L V6 (if it ever has an A/C issue, otherwise this car is like new).
Been reading the reviews on Amazon for the generic stets. People are complaining about the actual rings being too thin... and sometimes not actual HNBR
When I replaced the compressor on an '88 GL I only needed a couple 0-rings but I bought a complete rebuild kit. I think the whole rebuild set was only $4 or $5 at Auto Zone. This has been a few years ago but, I'd still expect them to be under $10. There's also the possibility that if you only needed 1 or 2 there would be other sizes that would fit applications on other models of your vehicles if needed. If you know what size you need it might be best to find a local business that specializes in seals and gaskets and buy what you need individually. You may have to pay a little more but then you'd know you were getting what you needed. I've got such a business here in town and have been there a few times when I only needed a piece of rubber gasket material or an o-ring that I didn't know the size of. I'd just take the old one with me and have them match it up. Sometimes if it's just an o-ring they'll hand it to me and say have a nice day. There has been a time or two the old one was damaged bad enough they didn't know for sure what I needed so they'd just give me 2 or 3 different sizes to be sure I got what I needed and not charge me anything. I suspect they do most of their business with industry and when an individual comes in they're not too worried about a couple $ .10 o-rings. They probably buy them by hundreds and probably have less than $ .01 each in them.
1 - 4 of 4 Posts
