Recent work and acquisition. | Ford Escort Owners Association (FEOA)
Discussion in 'Photo Forum' started by jay92gt, Dec 14, 2015.
  1. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    I have not posted up much on this forum in the past few years I've been a bit busy. I have gotten a lot of work done on my 94 EGT which I bought almost 3 years ago its under going basically a front to back re build and also a friend and I recently purchased the former Wizard racing mobile aka "Scrat"
    [​IMG]
    [​IMG]
    Car finally has an engine and trans in front fenders back on and some of the front suspension bolted up.
    [​IMG]
    [​IMG]
    [​IMG]
    Making the neighbors mad.
  2. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,172
    666
    363
    Sounds sick!
  3. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    It's getting a muffler. Needs to be at 87db to run at Lime Rock and right now it's probably about 130 maybe more.
  4. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    Alright the car is finally back on the ground and running after being on jack stands for two months. New Mfactory diff installed new engine mounts with poly inserts o/p gasket and ditsy seal. New rear struts just needs an alignment and some body work on the roof and it will be ready to do some SCCA events. Plans are as of now to run at the FCSCC season opening autox in Stratford CT on March 20th to shake it down and make sure everything works then the first on track racing will be April 29th and 30th at Thompson Speedway do some testing and tweaks to get the car right where I want it.
    [​IMG]
    [​IMG]
    [​IMG]
    ShakeZilla19 likes this.
  5. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    Almost forgot we put on a muffler so the car is a bit more quiet sounds pretty good for a $35 ebay flowmaster knock off.
  6. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    Some pics from when I was working
    The improperly installed Phantom Grip
    [​IMG]
    Wrecked one of the spider gears
    [​IMG]
    The new Mfactory unit
    [​IMG]
    [​IMG]
    Also removed and repainted the pacesetter header
    [​IMG]
  7. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    Also mounted up two sets of Hoosier scrubs. A set of well used SM6's for our autox break in and a set of 80% SM7's on the Rota's for the first track event.
    [​IMG]
  8. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    So the sunday event was cancelled because of inclement weather but we did get a few runs in on Saturday at the rookie school after I was done instructing. I had made a half run earlier in the morning just too see the course set up then my co driver took it out for a full on 100% lap in the afternoon. Car seems pretty quick for having the factory engine equipped but then I let a fellow competitor take the car out for a run and right off the line it started skipping so unfortunately I will not get another full blast run in it for another two weeks but we did find the problem in about 3 minutes worth of diag
    [​IMG]
    TheSilverShredder likes this.
